katkit
Mar 09, 2020Tutor
ORBI RBR850 -- frequent disconnects to WoW server
Suddenly for no reason, since this morning, every 15-30 minutes my connection with WoW (World of Warcraft game) drops. I get disconnected but can quickly reconnect within the minute. For context, my ...
Mar 11, 2020Guru - Experienced User
Be sure to check your CTS and RTS values. If they are at 64, please change both to 2347. Reboot both RBR and wireless devices.
skott79 wrote:You're definitely not alone in this. It looks like they either didn't test their firmware properly before they pushed it out or this bug got by them. Either way it sucks because I can't really game and I work from home and I'm getting drops during video calls. I hope they push out a fix ASAP!
RBK853 Wifi 6 (1 router, 2 satellites)
My firmware: V3.2.10.11_1.2.12
Poolrad
Mar 11, 2020Star
I'm really considering just buying another system to replace this, I'm in a work from home model and having to tether my laptop for work to my cell phone because my $700 orbi is a paperweight right now. Any suggestions to replace this system with that's stable and won't have issues like these? I can't handle anymore dropped video conferences because of this, at my breaking point and brand ruination for me.
- FURRYe38Mar 11, 2020Guru - Experienced User
Do you still have your prior router? if so, you can connect it up with your ISP modem. Turn OFF all wifi radios on the router. Then configure the RBR for AP mode. This will get Orbi AX working while NG gets this fixed.
If not, then you may want to return the system for a refund where you bought from.
Poolrad wrote:I'm really considering just buying another system to replace this, I'm in a work from home model and having to tether my laptop for work to my cell phone because my $700 orbi is a paperweight right now. Any suggestions to replace this system with that's stable and won't have issues like these? I can't handle anymore dropped video conferences because of this, at my breaking point and brand ruination for me.
