katkit
Mar 09, 2020Tutor
ORBI RBR850 -- frequent disconnects to WoW server
Suddenly for no reason, since this morning, every 15-30 minutes my connection with WoW (World of Warcraft game) drops. I get disconnected but can quickly reconnect within the minute. For context, my ...
Cam_A
Mar 12, 2020Aspirant
Just spent 2 hours on the phone with support,
The following troubleshooting steps in this order were taken to no avail.
- Downgraded firmware from 3.2.10.11_1.2.12 to 3.2.9.2_1.2.4.
- Changed CTS/RTS Threshold (1-2347): from 64 to 2347
- Restored to factory settings
- Added 3 port forwarding services to WOWs, (1119, 3724, 6012) correct me if I'm wrong on these.
Very pleasant technical service representative was explanatory and apologetic. Noted that they contacted Level-2 service and will call back tomorrow with an update to the situation. 3.2.10 apparently was rolled out to only a few users and has resulted in many reports of issues to the CS team.
I hope this helps out with everyone's anxiety here and we get a solid fix ASAP, will report back if I get any news.
jgosnell56
Mar 13, 2020Aspirant
Downgraded to 3.1.5.23 and had no issues all evening. This morning, units auto-upgraded to 3.2.9.2_1.2.4 and problem seems to be back. Also, RBR seems to be physically a lot warmer than I ever remember the unit getting.
- cruisencodeMar 13, 2020Apprentice
jgosnell56 wrote:Downgraded to 3.1.5.23 and had no issues all evening. This morning, units auto-upgraded to 3.2.9.2_1.2.4 and problem seems to be back. Also, RBR seems to be physically a lot warmer than I ever remember the unit getting.
Mine also auto-upgraded. I'm still testing to see if the issues are back.
cruisencode wrote:
Mine also auto-upgraded. I'm still testing to see if the issues are back.Confirmed. The issue is back. Time to downgrade again.
- FURRYe38Mar 13, 2020Guru - Experienced User
Be sure to check your CTS and RTS values. If they are at 64, please change both to 2347. Reboot both RBR and wireless devices.
