katkit
Mar 09, 2020Tutor
ORBI RBR850 -- frequent disconnects to WoW server
Suddenly for no reason, since this morning, every 15-30 minutes my connection with WoW (World of Warcraft game) drops. I get disconnected but can quickly reconnect within the minute. For context, my ...
Mar 13, 2020Guru - Experienced User
I see NG just posted v10.11 acutal files for download:
https://kb.netgear.com/000061769/RBR850-RBS850-Firmware-Version-3-2-10-11
Users may want to download these and apply them manually using IE11 or FireFox. I highly recommend a factory reset on the entire system after the RBS and RBR have been updated with these files. RBS first, then RBR lastly. Set up from scratch.
Be sure to check your CTS and RTS values. If they are at 64, please change both to 2347. Reboot both RBR and wireless devices.
- FURRYe38Mar 13, 2020Guru - Experienced User
Got word from a forum moderator. NG will be removing v10.11 from there update servers and from the support site. NG is still working on this. Please be patient.
- williscMar 13, 2020Aspirant
Ok thank you! Please keep the updates coming. I'm diligently following this thread.
- PoolradMar 13, 2020Star
So will they auto revert to a prior functioning firmware or do we have to do it ourselves? Most people aren't technical enough to do this.
From what others have said, they have removed v10.11 from the update servers and v3.2.9.2 is currently being pushed.
You can downgrade to v3.1 by manually downloading the FW files. Install them then try the upgrade to v3.2.9.2.
One user is reporting that since they put the v10.11 actual files up for download, his system seems to be working after he manually installed this version:
Or use your prior router as the host router and configure your Orbi AX for AP mode while we wait for NGs next FW update to hopefully fix all this.
