TadC3
Feb 16, 2022Aspirant
Orbi RBR850 - devices remain connected to router/satellite but has "no internet connectivity"
Device: Orbi RBR850 and satellite-1 Issue: - devices will be connected to the router/satellite with internet - randomly the device will lose internet but remain connected to the router/satelli...
Feb 17, 2022Guru - Experienced User
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
What channels are you using?
TadC3 wrote:
Device:
Issue:
- randomly the device will lose internet but remain connected to the router/satellite ("No internet connection")
- other devices in the same room remain connected to the internet and the Network Map shows that there is still internet service to the router and satellite
- in speaking with netgear support they say that this might be either a static to dynamic IP address issue? (I do not understand how to troubleshoot this) OR a firewall issue with an unauthorized access?
Attempted resolutions:
- I've power reset the router multiple times
- “reboot” through Orbi app
- Updated the firmware
Still the issue persists so I'm looking for assistance in how to troubleshoot. Please let me know what additional info I can provide. Thank you for any suggestions you may offer.
- TadC3Feb 18, 2022Aspirant
V4.6.3.16 which I believe is the latest
3,000sf
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
2 stories and 40+ feet. The satellite is connected to the router via cat5
Not sure how to determine this
Any Wifi Neighbors near by? If so, how many?Yes, many. I can probably pick up on a dozen other wifi networks at any time.
Again, this isn’t a drop of the wifi service or signal as other devices in the same room stay online when one device randomly drops out… very strange
- FURRYe38Feb 18, 2022Guru - Experienced User
3,000sf
2 stories and 40+ feet. The satellite is connected to the router via cat5< CAT6 is recommended. CAT5 is older and doesn't support 1000Mb speeds officially. Possible cable could be degrading good operation with the RBS.
Log into the RBRs web page and review the channel configuration under Basic Tab/Wireless Settings.
Try turning down the power output of the RBRs wifi radios from 100% to 50% and see if this changes anything. Under Advanced Tab/Advanced Settings/Wireless Settings
