JCCalifornit
Mar 01, 2022Tutor
Orbi RBR850 - Magenta light on and will not connect to internet.
Hi, My Orbi router will not connect to the internet. The magenta light remains on. Issue started after a reboot of the router. TS steps below: 1. Restarted router. 2. Reset router using button on...
JCCalifornit
Mar 01, 2022Tutor
Thanks for the response. It is connected to a NBN network connection device for FTTC connection. All of the connection light are up on the NBN device. Router firmware is V4.6.3.16_2.0.51.
Thanks
Thanks
JCCalifornit
Mar 01, 2022Tutor
In addition to my last post. I’ve just tried with another router and it works fine. It seems that the router is not saving any configuration settings that I input.
