blackbull123's avatar
blackbull123
Orbi RBR850 - Port Forwarding not working
I am having issues with opening ports/port forwarding with my Orbi RBR850 Mesh Wifi system. I go thru advance setting, and complete the process for port forwarding, but the ports are still not openin...
  • blackbull123's avatar
    blackbull123
    Dec 30, 2022
    Thank you CrimpOn! I believe you are correct, and my issue is with my ISP modem/router. I have an ATT BGW210, which can be a wifi router. I have the wifi disabled, and only using the wifi on my Orbi.
    I followed the steps you provided...the IP address is different on the Orbi Internal IP address vs. public/external IP address from ShieldsUp vs. the ATT router/modem IP address. All 3 different.
    Would this be addressed ATT router/modem setting...Firewall? Any idea where I go from here?
