rapshank1882
Sep 12, 2024Tutor
Orbi rbr850 + 2 rbs850 FW 7.2.6.31
Hi guys I have been running RBR850 + two satellites since 2020 and have never had any issues. I have BT 1gb fttp and my speeds are consistent. FW up to date on the rbr and RBs 7.2.6.31. My issue...
Sep 12, 2024Guru - Experienced User
When was the system FW updated?
Was it working well before the FW update?
We can't recommend v.31 FW. Seen other users having problems with it. NG is aware of it.
Try a factory reset and setup from scratch. If the problem continues, revert the system back to v.21. Most stable FW.
Ensure your wifi drivers are up to date on all PCs.
Try channels 1 and 40 or 11 and 48.
