rapshank1882
Sep 12, 2024Tutor
Orbi rbr850 + 2 rbs850 FW 7.2.6.31
Hi guys I have been running RBR850 + two satellites since 2020 and have never had any issues. I have BT 1gb fttp and my speeds are consistent. FW up to date on the rbr and RBs 7.2.6.31. My issue...
rapshank1882
Sep 12, 2024Tutor
Thanks, both. Pretty sure it's since latest FW applied but cannot be 100%.
Ill plug the work laptop using the ethernet tomorrow direct into rbr whilst the personal laptop is left on WiFi. Then tick off the rest after that!
Sep 12, 2024Guru - Experienced User
