ksog070274
May 14, 2022Aspirant
Orbi RBR850 + Orbi RBS850 Limited Connection due to DNS
Hi Community Experts I have had critical stability issues with my network (1 x RBR850 and 2 x RBS850 in a hardwired star configuration through 1GB network switch) since around january 2022. It wa...
ksog070274
Firmware.
ISP Modem.
I will try to follow your guide, I have not done these steps after the last update. I hope it works and I will get back to you on this thread. However if not I will rollback to the old version and follow your guidelines for restart and cross my fingers that it will not override the firmware.
Of course it would be best to have the updates working 🙂
Thanks
May 15, 2022Guru - Experienced User
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first...
Theres nothing past v4.6.8.2.
- ksog070274May 15, 2022Aspirant
Thank you.
I have right from the start re-configured modem to bridge mode and later on changed to a fixed LAN setup with a switch connecting the Orbi Router and 2 x Satellites. It has been working fine for a year or so until around new year and from update v4.3.6.16 is my best guess.
I was testing your other guidelines, but it didn't do the trick. I have now rolled back firmware starting with satellites and ending with router as recommended to last workable firmware v4.3.6.9 for all Orbi units, but I faced problems with re-booting it kind of looped and didn't complete.
I then factory reset all Orbi units with v4.3.6.9 installed, unplugged all and started with the router which works fine now. I have som problems with the satellites which just cycle in a reboot state. I have now disconneced them and I will do the power reset close to the router and with no conncetion to the switch.
I am not yet complete with the process, but I will inform you the outcome here in this thread.
Hi againg
Firmware is overridden automatically to the below version for the router at least. I will try and stick with this version and make it work as good as it possibly can, but as I recall it and in my notes, issues began around this version upgrade. I do not expect to much. I kind of have the feeling of being stuck here, but apperantly I got to accept this and cross my fingers for an upgrade in the future that works. I can't see what I possibly can do to get this fixed sadly enough.
I will post here when I am back up and running with final comments!
- FURRYe38May 16, 2022Guru - Experienced User
Yes. all v4.6.8x versions of FW have been removed from service. Most current for 8 series Orbi is v4.6.3.16.
