amweiss
Jun 05, 2024Tutor
Orbi RBR850 2.4 Ghz Not Showing Up
I've looked to see how I can connect to the 2.4Ghz network when I'm connect my iPhone (by default I only see th 5 GHz). As others have mentioned, I too am I'm trying to connect to my outdoo...
- Jun 05, 2024
Update...I was able to connect the plugs to 2.4Ghz system without making any changes. Maybe the RB850 is already set for this. The 2.4Ghz option was given to me during the connection process.
Jun 05, 2024Guru - Experienced User
What FW is loaded on the system?
You should have this if your have v7 FW loaded:
amweiss
Jun 05, 2024Tutor
Sorry, not sure what FW means, but that articles doesn't refer to the RBS850, and I can't find those setttings for IOT...maybe I'm just missing something obvious.
