amweiss
Jun 05, 2024Tutor
Orbi RBR850 2.4 Ghz Not Showing Up
I've looked to see how I can connect to the 2.4Ghz network when I'm connect my iPhone (by default I only see th 5 GHz). As others have mentioned, I too am I'm trying to connect to my outdoo...
- Jun 05, 2024
Update...I was able to connect the plugs to 2.4Ghz system without making any changes. Maybe the RB850 is already set for this. The 2.4Ghz option was given to me during the connection process.
amweiss
Jun 05, 2024Tutor
- CrimpOnJun 05, 2024Guru - Experienced User
Please "Accept as solution" so that people will see this issue is no longer open.
- FURRYe38Jun 06, 2024Guru - Experienced User
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
