jftobolski
Feb 02, 2023Aspirant
Orbi RBR850 access control - what does it actually do?
I have an Orbi RBR850. Everything working well, have >100 devices with IP reservations, hence I have only a small DHCP address range set aside for "other devices". Recently I've been seen an apple ...
jftobolski
Thanks for the reply - it does respond to ping, but only intermittently (meaning there might be 50-100 unsuccessful attempts, then 5-10 replies... repeat.
The log files weren't terribly self explanatory - the IP address in question shows up in the files, but not sure where exactly to look for actual packet traffic - anything you can suggest would be appreciated.
Good thought on the satellite that this device links to. It does move around. then again, so does a WEMO in-wall light switch so I wouldn't consider that high-grade information.
jftobolski
Sorry - an addendum. There is no lan.pcap file. There is an eth4.pcap and and BR.pcap. Neither are in plaintext though.
- CrimpOnFeb 02, 2023Guru - Experienced User
Oh, joy. Looks like Netgear decided to change how packet capture works in the AX products. (sigh)
pcap files are indeed binary files that can be displayed using a number of free programs. For Windows, I use Wireshark.
- SLK-PurdueFeb 02, 2023Luminary
Pcap files are for Wireshark. It is a free download and will decode the file. You like want the BR.pcap info
Scott
