jftobolski
Feb 02, 2023Aspirant
Orbi RBR850 access control - what does it actually do?
I have an Orbi RBR850. Everything working well, have >100 devices with IP reservations, hence I have only a small DHCP address range set aside for "other devices". Recently I've been seen an apple ...
FarmerBob1
Feb 02, 2023Luminary
Maybe a bit offf topic. But when I have had that happen, if you can get a MAC Address I've put it in "Access Control". Blocked it.
jftobolski
Update - have the packet capture running, and Wireshark installed. Will let it go for a bit
On the access control, yes I have blocked the MAC - but it's still getting onto the Wifi so want to see what it's talking to, if anything. I'd prefer if Access Control MAC filtering disallowed access to Wifi entirely.
On a side note, I foolishly turned on parental controls and not Access Control went away. Is there an easy fix?
- FURRYe38Feb 02, 2023Guru - Experienced User
Try to disable SPC using the Orbi app under Settings from the top left menu in the app...
Power off the RBR for 1 minute then back ON after applying the setting...should make the controls re-appear in the UI again?
