plee11
Sep 14, 2020Aspirant
ORBI RBR850 and RBS850 - Slow switching between devices
Hi, I just purchased the ORBI RBK853 which includes the RBR850 (AX6000) and 2 RBS850 satellites. Everything works well and it gets good speeds, I upgraded it from Google WiFi. However one thing about ...
Sep 14, 2020Guru - Experienced User
Fast Roaming and Daisy Chain are automatic on Orbi AX.
You can try powering the power output of the RBR and see if this helps any. Under Advanced Tab/AdvancedSettings/Wireless settings.
plee11
Sorry did you mean lowering? Thanks for the guidance.
