Anubis12
May 21, 2020Star
Orbi RBR850 and RBS850 Frequently Disconnects/Disappears
I've been dealing with RBR850 randomly disconnecting from the internet and/or wireless network dissapears. Likewise, the RBS850 suddenly disappears from the network as well along with the devices ph...
Darren_620
Jun 02, 2020Tutor
I have exactly the same router, ISP service and Netgear Modem with the disconnection issues that also started with the firmare updates. I identified that the disconnection happens when the large data packets are transfered such as the loading of fortnite on the XBoxes. Orbi / Netgear Support have been contacted several times with no resolution. Hope you get an answer that helps solve this otherwise I will return the product.
Bandito
Jun 02, 2020Luminary
Have you tried the old factory reset and reconfiguration trick since updating the firmware? With strange behaviors like this, it's probably worth a shot.
