somedude2
Apr 07, 2022Aspirant
orbi rbr850 continually repeatedly dropping internet (router solid magenta)
I have an Orbi RBR850 router with one satellite. I use Comcast internet with a cable modem Arris tg1682g set in bridge mode and the Orbi in router mode. I have been using this set up since getting ...
- Apr 15, 2022
As a follow up, it was indeed Comcast and the Orbi is back to performing just fine! Thanks for the help.
CrimpOn
Apr 07, 2022Guru - Experienced User
What function does the Raspberry Pi perform?
- somedude2Apr 07, 2022Aspirant
It runs a program called BassEQ which works with a miniDSP on the local network to add bass filters to subwoofer signals for movies. It needs a static IP to work.
- CrimpOnApr 07, 2022Guru - Experienced User
Thanks. People often use Pi's for DNS resolution (Pi-Hole) or as DHCP servers.
It seems strange that this started immediately after the Comcast outages. Could Comcast have reset their modem as part of the outage restoration, and perhaps 'changed something'?
Yea, I suppose anything is possible, but the modem is still in bridge mode. Not sure what else they could've changed that would affect the Orbi.
