somedude2
Apr 07, 2022Aspirant
orbi rbr850 continually repeatedly dropping internet (router solid magenta)
I have an Orbi RBR850 router with one satellite. I use Comcast internet with a cable modem Arris tg1682g set in bridge mode and the Orbi in router mode. I have been using this set up since getting ...
- Apr 15, 2022
As a follow up, it was indeed Comcast and the Orbi is back to performing just fine! Thanks for the help.
somedude2
It runs a program called BassEQ which works with a miniDSP on the local network to add bass filters to subwoofer signals for movies. It needs a static IP to work.
CrimpOn
Apr 07, 2022Guru - Experienced User
Thanks. People often use Pi's for DNS resolution (Pi-Hole) or as DHCP servers.
It seems strange that this started immediately after the Comcast outages. Could Comcast have reset their modem as part of the outage restoration, and perhaps 'changed something'?
- somedude2Apr 07, 2022Aspirant
Yea, I suppose anything is possible, but the modem is still in bridge mode. Not sure what else they could've changed that would affect the Orbi.
- CrimpOnApr 07, 2022Guru - Experienced User
Does anything show in the Orbi log corresponding to loss of internet?
All it shows is a bunch of DHCP IP to MAC addresses, a time synch to NTP when I last unplugged the router. Then a bunch of "older" events with time stamps of August 2023? with UPnP set event: AddPortMapping, more DHCP IP and then at the bottom is internet connected and initialize firmware to a 2023 date.
above the log it has current time/date correct.
As an addendum, since posting the first time, I did lose a connection again this time with the satellite going magenta and the router staying lights off. But both the hard connection and wifi stopped working.
