saurin13
Oct 01, 2020Tutor
Orbi RBR850 DHCP issues
I have an Orbi RBR850 Wifi 6 mesh system with 3 satellites using an ethernet wired backhaul. I have netgear GS108 switches on the LAN as well. Starting a couple of weeks ago, I could no longer...
Oct 01, 2020Guru - Experienced User
How are the RBS connected to the RBR, directly behind the RBR or thru the switch?
- FURRYe38Oct 01, 2020Guru - Experienced User
Also what is the Rev version of the GS108 switch? 108v#?
- saurin13Oct 01, 2020Tutor
Thanks for the quesitons. I'll get the data and share it when I get back home after the weekend. The satellites are connected to the orbi directly through ethernet (there are no switches in between). The switches are connected to the satellites.
- FURRYe38Oct 02, 2020Guru - Experienced User
Another suggestion would be to setup some IP address reservations for the RBS and your devices.
I would also make the default IP address pool smaller as well. I set mine to 192.168.#.100 thru.200. Since I only have about 30 devices. Still leaves plenty of room for more and then you have room for static IPs on either side of this pool.
- saurin13Oct 04, 2020Tutor
Hi the Orbi firmware of my Orbi is V3.2.16.6_1.4.4
The GS108's are v4
The Verizon ONT is I-211M-L
