saurin13
Oct 01, 2020Tutor
Orbi RBR850 DHCP issues
I have an Orbi RBR850 Wifi 6 mesh system with 3 satellites using an ethernet wired backhaul. I have netgear GS108 switches on the LAN as well. Starting a couple of weeks ago, I could no longer...
saurin13
Oct 04, 2020Tutor
I should clarify that the Sony TV has a wired connection (through one of the switches) to the orbi. However both my laptop and the wired devices will sometimes get 169. and its not just one wireless device. Even my nest cams then show they cannot connect to the internet.
Oct 05, 2020Guru - Experienced User
Have you set up any IP address reservations for your devices ON the router?
Has a power off for 1 minute then back on been performed since last update?
- saurin13Oct 05, 2020Tutor
Q: Have you set up any IP address reservations for your devices ON the router?
Yes I have for a few devices like the satellites, hubitat, and a few of the smart devices.
Q: Has a power off for 1 minute then back on been performed since last update?
Yes - multiple times. I have even unplugged all the satellites, powered them up one at a time. Made sure it had a connection with the base then turned on the next one.
Q: Has a factory reset and setup from scratch been performed since last FW update?Yes I have done this now twice. The issues still happen. Knock on wood, I have been good since about 5 days now since the last reboot.
- FURRYe38Oct 05, 2020Guru - Experienced User
Since 5 days you have been good. I'm wondering if there was a IP address conflict on your system before that may have been causing this...
- saurin13Oct 10, 2020Tutor
perhaps that could be an issue. how would that happen? its been 10 days now and no issues so far.
