BenZvan
Dec 07, 2021Tutor
Orbi RBR850 Extremely high wifi ping/latency
My Orbi system has very poor performance. Symptoms include: * Extremely poor ping times * Extremely long dns resolution time * speedtest still shows full 200Mbps connection rate * Streaming video...
BenZvan
Dec 09, 2021Tutor
Checking up again this morning and it seems better on this Mac but I just saw the Wifii blip from "connected" to "on" and back again.
It seems like which device gets the bad service changes. My Mac is getting 90Mbps over Wifi ([opt]-click Tx rate now says 219Mbps over 802.11n) but my phone is getting 17.
BenZvan
Dec 09, 2021Tutor
My first ever "LATENCY TEST ERROR" from speedtest. (over wifi)
"Could not connect to the test server. A firewall could be blocking the connection or the server might be having some issues. Please try again later."
- BenZvanDec 10, 2021Tutor
This perdformance is getting worse by the day. I want to open a support case before opening a return but my support is expired. Anyone know how to get help from Netgear or should I just start the return process and buy something else?
- FURRYe38Dec 10, 2021Guru - Experienced User
I'd start a return.
Thanks. I'll do that.
- BenZvanDec 13, 2021Tutor
Wow. They didn't get back to me until late at night and I didn't respond over the weekend. They sent me an email that the case would be automatically closed in 5 days and then closed it the next day after a total of less than 3 days. Now on the phone they're telling me my warranty is expired but I opened the case before my warranty expired.
Welp. They said "the power light is green so the hardware is fine."
Guess I'll try re-uploading the firmware and doing another factory reset.
- FURRYe38Dec 13, 2021Guru - Experienced User
What one user did:
https://community.netgear.com/t5/Orbi-WiFi-6-AX-and-WiFi-6E-AXE/New-RBR850-RBS850-Firmware-Version-4-6-3-16-Released/m-p/2150287/highlight/true#M21560
https://community.netgear.com/t5/Orbi-WiFi-6-AX-and-WiFi-6E-AXE/New-RBR850-RBS850-Firmware-Version-4-6-3-16-Released/m-p/2150391/highlight/true#M21575
https://community.netgear.com/t5/Orbi-WiFi-6-AX-and-WiFi-6E-AXE/New-RBR850-RBS850-Firmware-Version-4-6-3-16-Released/m-p/2150417/highlight/true#M21579What I did:
https://community.netgear.com/t5/Orbi-WiFi-6-AX-and-WiFi-6E-AXE/New-Online-Update-4-6-3-16-RBR850-RBS850/m-p/2155645/highlight/true#M22357
https://community.netgear.com/t5/Orbi-WiFi-6-AX-and-WiFi-6E-AXE/New-Online-Update-4-6-3-16-RBR850-RBS850/m-p/2154700/highlight/true#M22256Thought you were going to return it?
Yea. They won't let me return it because the power light is green therefore the hardware is 100% ok.
Did you purchase it from NG direct?
I did, yes. I'm going through the "extended warrenty" process to see if they can fix it.
I just spent almost 2 hours on a call with netgear's paid support team. They had me do yet another factory reset and the end result was that I need to buy a replacement. They said that since the warranty is expired even though I opened my original ticket before the warranty expired, Netgear is not willing to honor my warranty. I asked to be escalated to someone who could override it and was told I would get the same answer.
Notes from the gearhead support conversation:
* They wanted me to adjust implicit beam forming but I don't have that option on my router so we skipped it
* They said I should be getting hundreds of Mbps on a 900Mbps service. I think 802.11n is llimited to 3-400Mbps and the best I saw during testing was 120Mbps which would be totally acceptable if it was reliable and not high latency.
* They asked me to bring all my sattelites into the same room but also keep them 15' apart, which is a challenge for most people but my office is just large enough
* One test we did was with the RBR factory reset and connected only to power and the CB1200 and the sattelites both on wireless backhaul, basically the platonic ideal of a simple network setup. Same problems. Wifi rate was reasonable but ping was multiple seconds.
* I am astounded at how much advertising my router gave me just setting it up after a factory reset. I don't want armor and I don't want nannyware.
- BenZvanDec 15, 2021Tutor
I've searched the community but I guess I need help on how to reach out to a moderator.
- FURRYe38Dec 15, 2021Guru - Experienced User
Select on the moderator names I tagged and it will open up there profiles. Select Send message in there profiles.
- MNChuckDec 15, 2021Tutor
BenZvan -
I have the Netgear Orbi 753 system and have issues with it similar to what others have reported on this forum. I am patiently waiting for a firmware update that hopefully solves these problems and trying to keep up on the status of a fix by monitoring this forum.
I am astounded at the poor customer service position that Netgear has taken in your case in not honoring the warranty on their product even though you flagged an issue with it to them while the product was under warranty. This unfortunately pretty much fits the overall impression I have of Netgear from experiencing my own problems with the Orbi system and from reading the experiences of others in dealing with Netgear. They clearly are selling a defective product/system and are failing to stand behind it.
I would contact the Attorney General for your state and let them know that Netgear is failing to honor their warranty and ask for help in escalating your issue. Let Netgear know you are taking this action - it might get their attention.
I have purchased Netgear products for many years and as a result of the really terrible experience I have had with the Orbi system I will probably not purchase any Netgear products in the future as many others on this forum have also indicated.
MNChuck
Oh geez. I didn't even see the tags. They blended into your signature in my brain. Thanks.
:smileytongue:
- FURRYe38Dec 18, 2021Guru - Experienced User
Wanna try this?
- BenZvanDec 19, 2021Tutor
I'll give it a shot. Support kept saying they wanted me on v4.6.5.14 but never gave me a path to upgrade. No download link or anything.
Nope. If anything it's worse. I uploaded the new firmware, did a full reset, and went back through the setup again (happy to note it found my wired satellites extremely quickly).
Speed reported by Orbi router: 117Mbps
Speed reported by laptop and phone via Orbi WiFi: 4Mbps
Speed reported by laptop via wired connection to Orbi: 927Mbps
Wifi ping time to router: 600ms
Wired ping time to router: 0.6ms
- FURRYe38Dec 19, 2021Guru - Experienced User
Ok. Id keep working with support. Ask them about any RMA options.
Possible the RBR is just faulty...
- BenZvanDec 20, 2021Tutor
They told me last time they won't honor my warranty even though I started a return before my warranty expired. The return people told me the router is fine because the power light is green and the paid support people told me I have to buy a new router.
- FURRYe38Dec 20, 2021Guru - Experienced User
Please reach out to a forum moderator and see what options are avaialble and explain the situation to them.
I reached out to one last week and got no response. Perhaps they are on vacation. I will reach out to another.
- BenZvanJan 03, 2022Tutor
i have reached out to all three of the mods you mentioned over the last 3 weeks and received no response. Unless you have other suggestions or some special access to get their attention, I think I've reached the end of my options.
