rdlangy1
Aug 26, 2022Aspirant
Orbi RBR850 Firmware Update
HI There, My Orbi App has said for about 8 months that there is no Firmware update to be applied to the router. Currently it is on Firmware V4.6.3.16 Yet when I search on the Orbi website it me...
- Aug 26, 2022
Could just be that version has an issue with it. You can always upgrade manually.
I'd recommend upgrading the satellites first and then the router.
Aug 26, 2022Guru - Experienced User
rdlangy1 wrote:
HI There,
Yet when I search on the Orbi website it mentions about Firmware V4.6.9.11?
Any ideas why my Orbi App wont find the latest firmware to update to?
Ryan
rdlangy1
Thanks for the info - so are you saying I should update the satellite I have first - manually, then update the router manually, then power both off, and reboot them and all should be good?
Cheers
Ryan
