rdlangy1's avatar
rdlangy1
Orbi RBR850 Firmware Update
HI There, My Orbi App has said for about 8 months that there is no Firmware update to be applied to the router. Currently it is on Firmware V4.6.3.16   Yet when I search on the Orbi website it me...
  • plemans's avatar
    Aug 26, 2022
    Could just be that version has an issue with it. You can always upgrade manually.
    I'd recommend upgrading the satellites first and then the router.
