dujuarez
Mar 13, 2024Tutor
Orbi RBR850 Firmware Upgrade
I'm trying to update the firmware on my Orbi router. When I login to the router I go to firmware update. When it begins to check, it tells me that the router has no firmare updates but online line th...
Mar 14, 2024Guru - Experienced User
You can manually update.
Update the satellites first and then the router.
here's the guide for each
dujuarez
Mar 15, 2024Tutor
Thanks for all your help. I was able to update firmware without any problems.
Again, thank you.
David
- plemansMar 15, 2024Guru - Experienced User
Glad it worked!
You can mark it solved so others know what fixed it and so others aren't trying to still solve this.
A backup is a good idea too 🙂
