villot418
Nov 25, 2021Aspirant
Orbi rbr850 goes offline daily sometimes twice per day
I have an Orbi RBR850 with 2 satelites. This setup ran pecfectly since mid 2020 until October of 2021. The Orbi goes offline daily, I get no wifi or wired connections. I can access the orbi from m...
Nov 26, 2021Guru - Experienced User
Does the front LED turn ON on the RBR when this happens?
Power OFF the RBR and ISP modem fo 1 minute or more then back ON.
Has a factory reset and setup from scratch been performed since last update?
- villot418Nov 26, 2021Aspirant
Yes the led light turns to solid magenta
I don't power off the modem, I only power off the Orbi
Yes I performed a factory reset, that did not help
- FURRYe38Nov 27, 2021Guru - Experienced User
If the front LED turns on PINK, means it lost it's connection with the ISP modem:
https://kb.netgear.com/31030/What-do-the-LEDs-on-my-Orbi-mean
I would have the ISP check for anything seen on there logs around the time frame when this happens.
- coreybNov 29, 2021InitiateDon’t bother with all these suggestions as none of them will fix it. The dropout problem is known to Netgear. The firmware update that they forced to the router/satellites in October is the culprit. This causes satellites to disconnect devices forcing them to attempt to connect to the main router (which is often further away). The drop from 5ghz to 2.4ghz and the attempt that devices have connecting to a router further away causes the problems. Even wired satellites are impacted by this problem. They also removed the option to deselect “automatic firmware update” back in August-ish and so we are kind of stuck with it until they release a new firmware update to fix the issue. So far there is no news on when they will update from the current 4.6.3.16. Sucks big time but netgear won’t publicly acknowledge their mistake so I guess we just have to wait. There are other problems with that update which caused some devices to disconnect and reconnect to a satellite that is further away which also degrades the performance. It is annoying because for 10 months of this year, the whole system ran like clockwork - brilliantly. Call netgear and force them to address this issue sooner rather than later.
