drinkfairy1
Mar 08, 2022Aspirant
Orbi RBR850 I can no longer add devices, can anyone suggest what I can do?
Unable to add devices to network, any suggestions on what to do? I have the Orbi RBR850 with 1 satelite. It is attached to a modem for fiber optics. This just started a couple of days ago, I had no...
CrimpOn
Mar 08, 2022Guru - Experienced User
More detail would help.
When Network Settings on a device is opened:
- Does the WiFi network appear as one of the choices?
- When the WiFi password is entered, what happens?
Are there any devices which can be connected to the system with an ethernet cable?
drinkfairy1
On the first try it shows no networks, then when I rescan it shows the network and when i try t connect it says unable, try again later. I have 85 devices connected, and these use to connect easily, I may uninstall the Kasa app and reinstall it to see what happens.
