OldBullOne
Sep 06, 2020Aspirant
Orbi RBR850 into insight
Does anybody know if I can add this router into insight? Insight shows it, tells me to use a code (which it shows me) and go to the routers webpage...but I can't figure out what to do there...
Sep 06, 2020Guru - Experienced User
Have you tried using the Enter Serieal Number option at the bottom of the Insight app? You would look at the serial number at the bottom of the RBR...
OldBullOne
Tnx, tried that, as well as scanning the code...but insight won't let the Orbi in...I guess the attached photo shows the state of things.
Which is strange...why?
- FURRYe38Sep 07, 2020Guru - Experienced User
Seems like Orbi AX is not supported by the app. :smileyfrustrated:
- OldBullOneSep 07, 2020AspirantYup...although I don't know why not. This misleading part is the message to share that key somehow magically...
We'll wait and see,
Tnx,
H.
