Jmichaels001
Jul 13, 2020Aspirant
Orbi RBR850 IP Address reservations and DHCP address range
Im looking for direction related to using address reservations, and how to set the DHCP address range. I have an Orbi RBR850 and 2 satellites RBS850, a Synology NAS, and about 20 other devices attac...
arlomike
Jul 28, 2020Apprentice
Mikey94025 wrote:
arlomike wrote:I think Orbi's DHCP server is a mess. It doesn't seem to check if an IP is being used and dishes out a conflicting IP address. Ask me how I know this.
How did you determine this? Where these two devices assigned the same IP address from your Orbi? If you restarted the devices, did the IP conflict remain?
The DHCP server should never allocate the same IP address to two different devices (with different MAC addresses). That said, the DHCP server will not and cannot check if an IP address "is being used" for some non-Orbi reason (e.g., manual configuration of a static IP address, a stale IP configuration, conflicting DHCP servers on the network).
I have not seen any DHCP-issued IP address conflicts myself for the ~60 devices with my Orbi AX system.
I ran into this problem yesterday with two devices, both managed by Orbi's DHCP server. I did restart and it persisted. The only thing I can think of that happened earlier in the day was I unplugged Orbi to reroute some cables.. I not sure if DCHP tables persisted in in a reboot but I can say if it didn't persist, a potential problem can occur w/ conflicts.
Mikey94025
Jul 28, 2020Hero
arlomike wrote:I ran into this problem yesterday with two devices, both managed by Orbi's DHCP server. I did restart and it persisted. The only thing I can think of that happened earlier in the day was I unplugged Orbi to reroute some cables.. I not sure if DCHP tables persisted in in a reboot but I can say if it didn't persist, a potential problem can occur w/ conflicts.
Interesting. One final question - How did you know there was an IP conflict? Was it because the devices themselves complained, e.g., "Windows has detected an IP address conflict", and/or did you notice duplicate IP addresses in the Orbi admin website or Orbi app list of attached devices?
I like IP addresses to remain the same so I make a point of periodically adding DHCP address reservations via the admin website for as many of my always-on devices as possible. So that may be why I've not noticed IP address conflicts so far.
- arlomikeJul 28, 2020Apprentice
My wife complained she had intermittent problems surfing the net on her smartphone. Because I had to resolve an earlier issue btw an Echo Dot, Google mini and Ring, I suspected the same problem. I got on her phone and noted down her IP address and disconnected it from wifi and had her use LTE in the meantime. I then proceeded to login into the Orbi admin page and saw my iPad having the same IP. I restarted her phone but continued to have the same IP... WTF. I then assigned her a static IP outside the DHCP range and she was happy.. Happy wife, happy life. :)
I like my IPs to same too and with my previous router's DHCP server, when the devices renewed their IPs, they got the same IP. What I've noticed with this router's DHCP implementation is that IPs change for always on devices(IOT). I've reserved .2-100 in the DCHP range and I have 32 devices. I've noticed that the highest IP used was .45 this morning. It was .33 yesterday.
