Beantowm111
Jan 31, 2021Apprentice
Orbi RBR850 Link Aggregation
I have an ORBI RBR850 and Nighthawk CM1150 modem with xfinity gig (1.2 Mbps supposedly) internet. My speed via direct Ethernet is 960ish Mbps. I turned on port aggregation between the Orbi and nightha...
Feb 01, 2021Guru - Experienced User
Due to the LAN ports on the RBR and your network wired adapter connection rates are at 1000Mpbs which in most cases will max out at around 900 to under 1000Mpbs. You'll not see anything much over what your seeing now. Nature of the beast.
