Beantowm111
Jan 31, 2021Apprentice
Orbi RBR850 Link Aggregation
I have an ORBI RBR850 and Nighthawk CM1150 modem with xfinity gig (1.2 Mbps supposedly) internet. My speed via direct Ethernet is 960ish Mbps. I turned on port aggregation between the Orbi and nightha...
Beantowm111
Feb 01, 2021Apprentice
Thank you. So is there any advantage to having Port aggregation activated? Or is system better with it off?
Feb 01, 2021Guru - Experienced User
The overall speeed and handling of performances seems to be better with LAG enabled if you have a LAG enabled modem.
