enableIPv6
Aug 03, 2020Aspirant
Orbi RBR850 loses IPv6 connection daily
My brand new Orbi RBR850 loses IPv6 connections daily. To temporarily fix it, I have to re-enable it every day in the web GUI under Advanced > Advanced > IPv6 > Apply. No IPv6 configuration info or ...
- Jan 25, 2021
Good news, this problem seems to have been addressed by firmware updates. Now running V3.2.17.12.
Aug 03, 2020Guru - Experienced User
What FW version are you using? V32 is most current version.
I would make contact with NG support about this and let them know what you seeing with IPv6. Maybe something they need to correct.
- enableIPv6Aug 03, 2020Aspirant
Yes, I'm using the current firmware V3.2.15.32 on both my RBR850 router and RBS850 satellite.
- FURRYe38Jan 12, 2021Guru - Experienced User
Any progress on this?
enableIPv6 wrote:Yes, I'm using the current firmware V3.2.15.32 on both my RBR850 router and RBS850 satellite.
- enableIPv6Jan 25, 2021Aspirant
