enableIPv6
Aug 03, 2020Aspirant
Orbi RBR850 loses IPv6 connection daily
My brand new Orbi RBR850 loses IPv6 connections daily. To temporarily fix it, I have to re-enable it every day in the web GUI under Advanced > Advanced > IPv6 > Apply. No IPv6 configuration info or ...
- Jan 25, 2021
Good news, this problem seems to have been addressed by firmware updates. Now running V3.2.17.12.
Aug 03, 2020Guru - Experienced User
What FW version are you using? V32 is most current version.
I would make contact with NG support about this and let them know what you seeing with IPv6. Maybe something they need to correct.
enableIPv6
Yes, I'm using the current firmware V3.2.15.32 on both my RBR850 router and RBS850 satellite.
- FURRYe38Jan 12, 2021Guru - Experienced User
Any progress on this?
enableIPv6 wrote:Yes, I'm using the current firmware V3.2.15.32 on both my RBR850 router and RBS850 satellite.
- enableIPv6Jan 25, 2021Aspirant
- FURRYe38Jan 25, 2021Guru - Experienced User
Good to hear. Enjoy. :smileywink:
