Jeff837
Nov 15, 2023Initiate
Orbi RBR850 more detailed network info??
I'm looking to be able to glean more detailed info about my network from the RBR850 router, such as actual signal strength of connected devices, which is not shown on the main Orbi web page or app. ...
CrimpOn
Nov 16, 2023Guru - Experienced User
Orbi routers use the Simple Object Access Protocol (SOAP) to communicate with the Orbi 'app'.
https://en.wikipedia.org/wiki/SOAP
If you have access to Microsoft Excel, there is a spreadsheet that will display all sorts of useful information, including the signal strength and link rate of individual devices. Fill in the router password and click in the big box.
The spreadsheet uses Excel macros to extract information from the router and display it on a series of tabs.
Alas, it is beyond my capability to turn the macros into something else.
- CrimpOnNov 16, 2023Guru - Experienced User
