InstantDreams
Sep 20, 2021Aspirant
Orbi RBR850 previous 2.4GHz devices not connecting at all
I recently transitioned from a Netgear Nighthawk R7000 to a Netgear Orbi RBR850. On my Netgear Nighthawk R7000 I separated the 2.4G and 5G SSIDs. For the Netgear Orbi RBR850 I had no choice but t...
InstantDreams
Sep 22, 2021Aspirant
Here's the Wireless settings where I disabled 5G:
Here's the Advanced Wireless settings:
Let me know if there is anything else you may need.
raven_au
Sep 22, 2021Virtuoso
There are two things you could try and I would recommend to try each one seperately so you can understand if one or the other makes a difference.
First select a fixed channel for the 2.4Ghz band of 1, 6 or 11 depending on what other routers near you use, pick the least crouded.
I have devices that behave badly when the channel is set to auto so you might too.
Second disable AX support on the 2.4Ghz band.
Usually people that can take advantage of AX mode (ie. WiFi 6) will be using the 5Ghz band so disabling it for the 2.4Ghz band is not a real problem.
- FURRYe38Sep 23, 2021Guru - Experienced User
Also try setting CTS value to 2347.
