zignice
Oct 22, 2020Aspirant
Orbi RBR850 rebooting Randomly
I am having a reboot problem with Orbi AX600. I see where others have this issue, but I do not see that a solution has been found. I am using the Orbi AX6000 Tri-Band Mesh WiFi System (1 ...
Oct 22, 2020Guru - Experienced User
Is the Orbi system operating in Router or AP mode?
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
https://kb.netgear.com/19668/Link-Rate-and-Transfer-Speed
Armor, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s).
You can find other speed diagnosis steps in the community faq: https://community.netgear.com/t5/Orbi-AX/Community-FAQ-My-Orbi-speeds-are-slow-inconsistent-and-don-t-my/m-p/1982974/highlight/true#M7849
zignice
Oct 23, 2020Aspirant
Tried changing the settings. It will take a few days to see if it makes a difference and then which of the settings was causing the issue.
- FURRYe38Oct 23, 2020Guru - Experienced User
