zignice
Oct 22, 2020Aspirant
Orbi RBR850 rebooting Randomly
I am having a reboot problem with Orbi AX600. I see where others have this issue, but I do not see that a solution has been found. I am using the Orbi AX6000 Tri-Band Mesh WiFi System (1 ...
gobblegobble
Jan 22, 2021Aspirant
I've been having this same issue. Been on the phone with Netgear multiple times. This last time they had me change the Routers settings to use Google's DNS...not sure why that would cause a reboot.
Jan 22, 2021Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
gobblegobble wrote:I've been having this same issue. Been on the phone with Netgear multiple times. This last time they had me change the Routers settings to use Google's DNS...not sure why that would cause a reboot.
