rpolly30
Jul 04, 2020Guide
Orbi RBR850 Sattelite disconnects and slow
I purchased the Orbi two weeks ago. The main unit is set up in the living room and the sattelite is about 70 feet away from it. I am getting great speeds when everything works. The backhaul says "good...
Jul 04, 2020Guru - Experienced User
Try moving it closer and/or laterally. There's a minimum distance (30ft) but 70ft could be a bit far depending on whats within your walls.
Also try moving it laterally as if hvac or other materials in the wall could be causing interference.
