rpolly30
Jul 04, 2020Guide
Orbi RBR850 Sattelite disconnects and slow
I purchased the Orbi two weeks ago. The main unit is set up in the living room and the sattelite is about 70 feet away from it. I am getting great speeds when everything works. The backhaul says "good...
Jul 04, 2020Guru - Experienced User
Be sure that CTS and RTS values are changed to 2347 under Advanced Tab/Advanced Settings/Wireless Settings
rpolly30 wrote:
I purchased the Orbi two weeks ago. The main unit is set up in the living room and the sattelite is about 70 feet away from it. I am getting great speeds when everything works. The backhaul says "good"
I have a computer and xbox hardwired in to the satellite.
A few times a day the satellite will either complete crash or will come to a complete slowdown (25 mpbs). If I reboot it comes back on and functions fine until the next crash.
Things I have tried:
Moved Sattelite around
Channels are set to 6 (2.5) and 48 (5)
20/40 coexistence unchecked
Enable WMM Checked
CTS/RTS threshold set to 2000 on both
What other things should I try?
rpolly30
Jul 04, 2020Guide
Firmware:
3.2.15.25_1.3.15
It is connected to an Aris TM1602
I am on channel 6 for 2.4 and channel 48 for 5
I don't have circle, daisy chain, or fast roaming as an option. I did just change to short preamble from auto and I updated CTS and RTS to 2347 from 2000.
I will see what happens in the next 12 to 24 hours (usually it crashes every 30 minutes or so).
We have two neighbors nearby (our home is in between the two of them) and one across the street.
3.2.15.25_1.3.15
- FURRYe38Jul 04, 2020Guru - Experienced User
What channels are your two neighbors using?
Hopefully the CTS change will help you out.
We'll get this thread moved to the Orbi AX Forum.
