chughes8788
Feb 28, 2023Tutor
ORBI RBR850 Slow Speed Test on Computer vs Orbi Speed Test
I did a speed test on the orbilogin.net and the speeds come back at 551.67 Mbps Download and 22.30 Mbps Upload but when i got to speedtest.net on several computers it says.78.50 Mbps Download and 21....
chughes8788
Feb 28, 2023Tutor
I’ve not done a reset. I really didn’t want to if I didn’t have to. I’ve checked all traffic, parent and other controls. I’m on 5ghz. I tested it with a Dell Laptop and a Samsung Laptop…. Both windows. I hadn’t tried on my MacBook.
Feb 28, 2023Guru - Experienced User
So you tried both laptops hardwired?
What site did you use?
Did you try a simple reboot then?
- chughes8788Feb 28, 2023TutorYes I did a reboot and I tried wifi and directly into with Ethernet and neither improved.
I used speedtest.net- plemansFeb 28, 2023Guru - Experienced User
I'd try the reset then.
