nvasion
Sep 11, 2023Aspirant
Orbi RBR850 Slow upload speed on ethernet
Hi all, I am trying to track down this issue that I am having with my orbi. My ISP is 1Gbps up and down however I am seeing extremely slow speeds for upload from my RBR850. This is the things...
Sep 11, 2023Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
What is the brand and model of the ethernet adapter in the wired PC?
Drivers up to date?
Armor or Traffic Meter enabled on the RBR?
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
What speed test app are you using?
Happens with other ethernet connected PCs?
- nvasionSep 11, 2023Aspirant
ISP modem: Calix gigapoint GP1100X
NIC: Realtec PCIe 2.5GbE
Drivers are up to date
No Armored or Meter enabled
Reboots have occurred in sequence as well.
Speedtest.net and fast.com are the speed test providers
Don't have any other PCs that have ethernet ports in the house.
- FURRYe38Sep 12, 2023Guru - Experienced User
What does this one wired PC seen when connected directly to the ONT?
Might try a full on Factory reset on the RBR, power OFF the ONT for 1 minute then back ON, then walk thru the setup wizard with the PC and web broswer. Don't enabled anything on the RBR after the setup completes. Run some speeds tests soon after you complete the setup.
Be sure the CAT6 Cable is STP.
What does the CPU and memory usage show for values on the RBRs debug page? routerIP/debug.htm
- nvasionSep 13, 2023Aspirant
So I don't notice any problem directly connected to the modem so its definitely the Orbi.
All cables are CAT6 STP.
CPU Load: 19.92%
Memory Usage(Used/Total): 301 MB/874 MB
I'll try a factory reset when I can.
