nvasion
Sep 11, 2023Aspirant
Orbi RBR850 Slow upload speed on ethernet
Hi all, I am trying to track down this issue that I am having with my orbi. My ISP is 1Gbps up and down however I am seeing extremely slow speeds for upload from my RBR850. This is the things...
nvasion
ISP modem: Calix gigapoint GP1100X
NIC: Realtec PCIe 2.5GbE
Drivers are up to date
No Armored or Meter enabled
Reboots have occurred in sequence as well.
Speedtest.net and fast.com are the speed test providers
Don't have any other PCs that have ethernet ports in the house.
Sep 12, 2023Guru - Experienced User
What does this one wired PC seen when connected directly to the ONT?
Might try a full on Factory reset on the RBR, power OFF the ONT for 1 minute then back ON, then walk thru the setup wizard with the PC and web broswer. Don't enabled anything on the RBR after the setup completes. Run some speeds tests soon after you complete the setup.
Be sure the CAT6 Cable is STP.
What does the CPU and memory usage show for values on the RBRs debug page? routerIP/debug.htm
