Arkiteker
Sep 13, 2022Tutor
ORBI RBR850 Slow Upload
I have an Orbi RBR850 running Firmware Version: 4.6.9.11 I have fiber internet of 500/500. I have tested my speed directly from the NID and received 492/491. I have also tested it from NID>Switch ...
Sep 14, 2022Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Is there a switch in between the ONT and RBR? Can you connect the RBR directly to the ONT?
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
- ArkitekerSep 14, 2022Tutor
It's not the NID, it's not the cables...it's the Orbi. There is SOMETHING in the router throttling the Upload speed because when IT is removed from the equation everything works as it should. NetGear has yet to come up with a solution.
- iyangSep 14, 2022NETGEAR Expert
Hi Arkiteker ,
As you mentioned that removed from the equation and then upload speed back to normal.
Can I know what's function/ application removed from the equation ?
Thanks.
- ArkitekerSep 15, 2022Tutor
Does everyone see what I'm talking about? NetGear doesn't read or care.
Iyang, the device I removed was the ORBI ROUTER!!!! This is what I'm saying, the issue is the router itself, not the DIA Connection, Not the NID, Not the cables, Not the computer...IT'S THE ORBI ROUTER.Do you clearly understand this? There is SOMETHING inside the router or its settings that slows the Upload speeds.
DO YOU UNDERSTAND THIS?
