Beneke
Sep 28, 2020Aspirant
Orbi RBR850 speed limited on ethernet and wifi
The orbi router seems to throttle the speed on it's lan ports and on wifi Rebooting the orbi helps for a short while after some time the speed drop to around a 90Mbit connection usually some inter...
Sep 28, 2020Guru - Experienced User
Please post about this over in the Orbi AX forum:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Thank you.
