Beneke
Sep 28, 2020Aspirant
Orbi RBR850 speed limited on ethernet and wifi
The orbi router seems to throttle the speed on it's lan ports and on wifi Rebooting the orbi helps for a short while after some time the speed drop to around a 90Mbit connection usually some inter...
Mikey94025
Sep 29, 2020Hero
Does this help? https://community.netgear.com/t5/Orbi-AX/Community-FAQ-My-Orbi-speeds-are-slow-inconsistent-and-don-t-my/m-p/1982974
You seem to have verified the slow down is at the base station, make sure to disable the functionality mentioned in the FAQ.
Beneke
Sep 29, 2020Aspirant
Checked out the faq, seems like my steps are in order
I turned off traffic monitor but that did not show any difference
as is what i would expect from a decent traffic manager :-(
