Beneke
Sep 28, 2020Aspirant
Orbi RBR850 speed limited on ethernet and wifi
The orbi router seems to throttle the speed on it's lan ports and on wifi Rebooting the orbi helps for a short while after some time the speed drop to around a 90Mbit connection usually some inter...
Sep 30, 2020Guru - Experienced User
Has a power off for 1 minute then back on been performed since last update withthe ISP modem and RBR?
Beneke wrote:The orbi router seems to throttle the speed on it's lan ports and on wifi
after some time the speed drop to around a 90Mbit connection usually some internet glitches occurr
I if connect directly to the modem of the isp I get 800mbit plus connection
Using a linksys router inbetween I also get 800mbit plus connection
After a reboot I usually get the 800mbit speed for a while but then it drops again making me very sad about this very expensive product.
Since I'm still in warranty I'm thinking about returning this product unless this gets fixed soon.
I first thought it was an issue with the isp but did some extensive testing with them and there is no issue with their connection.
Beneke
Oct 11, 2020Aspirant
I wonder what happpened
I did extensive testing for more then a week continous issues with the netgear router
and now for 3days in a row it is acting like it should
no changes on the netwerk what so ever :-s
Like the guys from netgear fixed it without letting it now
and probably that is what happened
because i have now a firmware version which is higher then the one on the download site
and this was a week a ago the same firware version
I am now on v3.2.16.6 which seems to behave nice on my network (before v3.2.15.32)
So far no throttling on lan ports, no throttling on the wireless connection.
If this solution holds up I'm again a happy customer
Let's keep an eye on it for the comming weeks
Lot's of video conferencing that needs to run smoothly
crossing my fingers
