Beneke
Sep 28, 2020Aspirant
Orbi RBR850 speed limited on ethernet and wifi
The orbi router seems to throttle the speed on it's lan ports and on wifi Rebooting the orbi helps for a short while after some time the speed drop to around a 90Mbit connection usually some inter...
Beneke
Oct 11, 2020Aspirant
I wonder what happpened
I did extensive testing for more then a week continous issues with the netgear router
and now for 3days in a row it is acting like it should
no changes on the netwerk what so ever :-s
Like the guys from netgear fixed it without letting it now
and probably that is what happened
because i have now a firmware version which is higher then the one on the download site
and this was a week a ago the same firware version
I am now on v3.2.16.6 which seems to behave nice on my network (before v3.2.15.32)
So far no throttling on lan ports, no throttling on the wireless connection.
If this solution holds up I'm again a happy customer
Let's keep an eye on it for the comming weeks
Lot's of video conferencing that needs to run smoothly
crossing my fingers
Mikey94025
Oct 11, 2020Hero
Glad to hear things are now working for you. Might've been ISP modem and/or Orbi restarting too.
Beneke wrote:Like the guys from netgear fixed it without letting it now
Note that 3.2.16.6 has been available for over a month. You can find the latest Orbi AX firmware downloads at https://www.netgear.com/support/product/RBK852#download.
However, usually the safest and most convenient thing is to let your Orbi update itself and only jump onto a newer firmware issue if you're experiencing a specific problem that it fixes or if you want to always have the latest (and hopefully, greatest) firmware version - Like many of us here. :-)
