Beneke's avatar
Beneke
Orbi RBR850 speed limited on ethernet and wifi
The orbi router seems to throttle the speed on it's lan ports and on wifi
Rebooting the orbi helps for a short while
after some time the speed drop to around a 90Mbit connection usually some internet glitches occurr
I if connect directly to the modem of the isp I get 800mbit plus connection
Using a linksys router inbetween I also get 800mbit plus connection
After a reboot I usually get the 800mbit speed for a while but then it drops again making me very sad about this very expensive product.
Since I'm still in warranty I'm thinking about returning this product unless this gets fixed soon.
I first thought it was an issue with the isp but did some extensive testing with them and there is no issue with their connection.
I also tried the factory reset as mentioned on some other topic
Highspeed internet acces laster for about 2 mins  600mbit plus download 50mbit upload
donwloads limited again to 90 mbit upload goes anywhere between 0.5mbit en 40mbit
Really dissappointed in this product
PS I also checked this Faq  https://community.netgear.com/t5/Orbi-AX/Community-FAQ-My-Orbi-speeds-are-slow-inconsistent-and-don-...
But no look so far :-(
Basic routing functionality that works well  with other routers is a problem as well as wifi.
I can't keep resetting the router which seems to solve the issue for a while between 2min and 60mins and then everything is throttled again.
  • If you have already checked the checklist provided by Mikey94025 , especially point# 2 related to the ISP mode/router, then I have additional questions to you please:
    • Do you have any mesh speakers (e.g. Sonos) attached to your Orbi? Wired or wireless?
    • Do you have any wifi repeaters in your network, or any device that can act as a repeater?
    Fo me it looks like you have a device in your network causing this issue. It will be good if you can list the types of all devices that you have in the network.
  • FURRYe38's avatar
