Meadster
Sep 26, 2022Tutor
Orbi RBR850 sudden slow/ restricted speed
Hi I Have recently bought a 3 pack system all working ok and has been for around 3 weeks Suddenly, wifi seems to be limited to a maximum of 250mb. Nothing has changed in the setup, all connected ...
Meadster
Oct 05, 2022Tutor
Correction on size, that should have been 600sq ft per floor so a total of 1,200sq ft. It had occurred that I may have too much wifi although it seems to be behaving and running as it should. I'll have a look and try with turning them on and off or adjusting the power as suggested and see what happens.
Oct 05, 2022Guru - Experienced User
Ok. That makes more sense. Ya, 1200sqft the RBR alone can handle that. If you have two RBS deployed, I would turn OFF one of them then also reduce the power to 25%.
I can get away with just 1 RBS in my 5000sq ft home and run 50% normally.
