Meadster
Sep 26, 2022Tutor
Orbi RBR850 sudden slow/ restricted speed
Hi I Have recently bought a 3 pack system all working ok and has been for around 3 weeks Suddenly, wifi seems to be limited to a maximum of 250mb. Nothing has changed in the setup, all connected ...
FarmerBob1
Oct 05, 2022Luminary
I just read through this and don't I think I saw it mentioned if, "Can you, after getting your login info from your ISP, bypass your BT Router and connect the RBR to the ONT directly." That's how I have mine.
Reducing the amount of gear on the front end can work wonders.
If this has been mentioned and answered, just tell me to "get lost". If not let us know if you can and we'll go from there. I have mine done that way and it's one of the two ways: 1. Just plug in your RBR and use whatever protocol to login with, or; 2. Like mine, I have to have a Tagged 201 VLAN on the WAN, easy to do, and login via PPPoE with the User Name and Password that my ISP gave me. Works great and the "New" thing to do. If your ISP allows.
Hope this helps?
ekhalil
Oct 05, 2022Master
Correct, this was suggested earlier here: https://community.netgear.com/t5/Orbi-WiFi-6-AX-and-WiFi-6E-AXE/Orbi-RBR850-sudden-slow-restricted-speed/m-p/2261801/highlight/true#M38992
But the answer was that Orbi is in AP mode and the main router is the ISP router.
