rdouma
May 30, 2024Guide
Orbi RBR850 unstable/DHCP assignment issues after reboot
Post concerns a RBR850 and 2 RBS850 satellites, all running firmware version V7.2.6.31_5.0.24. Summary: I have to turn off all WiFi devices near the router in order to get a successful reboot whe...
May 30, 2024Guru - Experienced User
So with all these devices online, and setup IP address reservations, does the system work ok?
I see some devices that you might consider setting a Static IP address ON that would be outside of the suggested default DHCP IP address pool range.
You have lots of plugs and lights. Wondering if some of these could be causing issues. Wondering if the system is bogging down.
What channel configurations are currently set on the router?
What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite ‌‌🛰
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
What FW version was loaded prior to v.31?
Prior FW working?
