rdouma's avatar
rdouma
Guide
May 30, 2024
Orbi RBR850 unstable/DHCP assignment issues after reboot
Post concerns a RBR850 and 2 RBS850 satellites, all running firmware version V7.2.6.31_5.0.24.
Summary: I have to turn off all WiFi devices near the router in order to get a successful reboot where devices get an IP-address via DHCP. If I don't, devices don't get a DHCP address and get a self-assigned DHCP-address instead.
Background: I have a lot of WiFi-enabled devices. I suspect this was introduced mainly by the latest firmware that was probably installed automatically (I had auto-update on before). I cannot say for sure because as far as I know there is no log or notification when firmware gets updated, and the Release Notes of the firmware are of no help either because they don't mention the release date. My experience is: I had been adding several Wiz lightbulbs in the last week of April. Everything was working fine when I left for a trip on May 2. On May 3 I notice my house was offline in Apple Home. I asked a relative to reset the router and the Apple TV that is the HomeKit hub, but nothing helped: it stayed dark. When I came back on May 11 I started this journey to figure out what is going on.
Coming back I could not get things to work AT ALL. I discovered I had to basically turn off ALL devices in the house that had WiFi, restart the router, wait for a minute or 10 and then slowly turn devices back on. If I did that too quickly devices would not connect (I suspect not get a valid IP) and subsequent devices would then also not connect reliably. Absolute nightmare that had me at the end of my wits for 3 days. I then decided to factory reset it all and set it up anew in a more organized way.
Short summary from the top of my head:
  1. Scanned networks with WiFi-explorer and made sure I chose channels that are not having too much competition. This is a residential area with relatively large distances between the houses (next house is about 20 meters from my place). Tried to play all kinds of combinations of 2.4 and 5Ghz channels, but didn't make a big difference. Played with all kinds of tweaks on the router, no big difference.
  2. Hardwired first satellite to router. Made router connect quicker but no success neither.
  3. Named devices for ALL devices that should be online (Sonos, lights, etc.). I gave DHCP range 150-254 and organized the IoT devices below that.
  4. No big difference, so decided to set up the IoT network. Moved most devices over. Not a huge difference but at least it's organized.
  5. Decided to make IoT network 2.4Ghz only. Regretfully I cannot make the regular network 5Ghz only or assign it a different channel. seems sub optimal but not sure; this surpasses my skillset; I'm a "software guy".
Finally I discovered the ONLY way to reboot successfully in about 80-90% of the cases (which I had to do countless times because assigning a device a fixed IP only works when you apply it and reboot it) is:
  1. Turn off ALL wifi-devices near the router (computers, lamps).
  2. Restart the router and wait for about 5 minutes or at least until the final satellite in the chain says the backhaul is "good".
  3. Then turn on back my wifi-devices in my office.
Sometimes I need to do that 2 or 3 times but then it works fine. Sometimes for a few days on end. Now going 3 days already without a reboot.
I also noticed it makes a huge difference if I move the router a few centimeters (!). I'm still figuring out the optimal position now. I currently am trying to find the best position for the router. I moved the RBR850 to another room with long cables to allow me to try and find the optimum spot. By the way; I had it running fine for YEARS with the router in my office and a wireless backhaul to the satellites.
TL/DR: I suspect the latest firmware update made the router unstable and it seems to have trouble assigning DHCP addresses if wifi-devices are turned on before it finalizes its booting sequence. Assigning them IP-addresses via named devices doesn't seem to help; the devices need to be OFF. Not doing so makes the entire house fail in DHCP-assignments.
  • KevinLiT's avatar
    KevinLiT
    NETGEAR Moderator
    Hello @Dws6001,
    Thank you for providing that information!
    I will forward this issue to our experts for further evaluation.
    Best,
    Kevin
    NETGEAR Team
  • KevinLiT​
    I have had this same issue for a couple years across several FW versions. I upgraded FW months ago, currently on 7.2.7.15 and have the same exact issue. It is absolutely maddening that netgear can’t handle network devices. The amount of time it takes to get this stuff back online is rediculous. I am currently running between 86 and 96 devices online at any given time. On a reboot it can’t reassign the IPs completely leaving many offline for days requiring yet another reboot, again, and again, and again until finally everything takes. And after doing some reading it appears newer routers like the 960 do the same thing with lots of devices. Next step is trash and buying another brand. Please help fix this
    • FURRYe38's avatar
      Currently have about 60 devices online with my 963 series and v.15 FW. Not seeing any DHCP issues.
      I have my two RBS assigned IP address reservations and also have a smaller DHCP IP address pool size as well. .100 to .200.
      Also IPv6 is disabled on v.15 FW as well as there is a known issue with this version of FW that breaks IPv6. Thought I don't need IPv6 as my ISP doesn't support native IPv6.
      System is working well for me on v.15. Longest time run with it was just over 30 days: Share your Orbi 350, 750, 850 or 960 series system UpTime | NETGEAR Communities
      Someone else with the 850 series seeing a long time running with this FW version on there system: Share your Orbi 350, 750, 850 or 960 series system UpTime | NETGEAR Communities
      If you don't think you can get v.15 working, then revert the system back to v.21. Thats was considered the most stable FW.
    • rdouma's avatar
      rdouma
      Guide
      Dws62001​ To avoid these issues the only solution I have found is to disable DHCP in the Netgear altogether and running another computer with a DHCP server (in my case ISC DHCP on a Raspberry Pi). Never looked back.
    I don't think so, I have had this same problem for a long time.
    I was excited to read that, for you, not making any DHCP reservations resolved the problem.
    I reinstated my 850's to see if that would work and to my surprise removing all my DHCP reservations did allow the system to reboot and continue issuing addresses, unfortunately, after less than 24 hours one of my satellites started showing magenta light which I took to mean it could not renew its IP address and sure enough my Android phone could not renew its address either.
    A couple of things to note:
    1) This is on V7.2.6.21_5.0.20 and I have seen it on earlier firmware versions.
    2) Some time after I first saw this I tried my RBK50 kit and saw the same problem leading me to think it is related to some sort of a race in the DHCP server when the number of devices is large, possibly more than about 50 but more than 80 is when I really started having a problem.
    3) Following a factory reset the system, which generally works to get the system going again, will sometimes reboot successfully a couple of times before the same problem occurs again.
    I have no idea why this happens but once it starts it doesn't seem to stop, and I have no reliable work around, the only thing I can do is disable the router DHCP server and use my NAS for DHCP instead.
    This has been a problem for years and Netgear not paying any attention to the forums is just not good enough, but then they give only three months support on new purchases, so  ...
    Ian
    • rdouma's avatar
      rdouma
      Guide
      Eh... where did I say that? I surely didn't intend to say that; one of the steps I used to get back to a workable solution was the opposite of that: I basically have all known devices in my house as a named device now.
      Very well possible it's related to the amount of devices. I have a bunch of them and a large amount was added over the last months when installing Wiz light bulbs.
      Yeah, with you on that one. I would expect that you would never want to restrict users to be able to easily submit bug reports but no. Luckily there's this forum and some power users here that seem to know their way around this but in my opinion NetGear should be welcoming bug reports instead of trying to make it hard to submit one.
      • raven_au's avatar
        raven_au
        Virtuoso
        Umm ... reading your post again I think I misunderstood, sorry.
        Nevertheless, the dhcp server is probably single threaded and applications like this usually spawn a sub-process for each request to increase throughput. So doing that means they need to record information about the address assignments in a file somewhere because sub-processes are themselves isolated from one another. If there are multiple concurrent requests (a lot of devices wanting to register at once) and the locking of that file isn't right or isn't even done then you can easily get corruption in the file.
        I've seen that before in Linux, for years we had a lot of trouble with /etc/mtab (mounted mounts list), in spite of quite a sophisticated locking algorithm it frequently got corrupted during heavy mount activity. It wasn't until /etc/mtab was made a symbolic to the proc file system mount table it was resolved (the proc file system mount tables are files generated on the fly from kernel data structure, they are not written to).
        So, it is easily possible the dhcp server is broken, of course the problem is that Netgear hasn't done anything about it or aren't competent enough to fix it if they have tried. The problem is no secret either, there have been a number of reports of it over the years.
        For my part I have never been in a position to log a call with support because of the support policy and even if I was within the twelve weeks period at some time I'm not at all sure I would be willing to subject myself to the pain and suffering of what logging a support call involves.
        Ian
  • FURRYe38's avatar
    So with all these devices online, and setup IP address reservations, does the system work ok?
    I see some devices that you might consider setting a Static IP address ON that would be outside of the suggested default DHCP IP address pool range.
    You have lots of plugs and lights. Wondering if some of these could be causing issues. Wondering if the system is bogging down.
    What channel configurations are currently set on the router?
    What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
    https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite ‌‌🛰
    Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
    What FW version was loaded prior to v.31?
    Prior FW working?
    • rdouma's avatar
      rdouma
      Guide
      Channel configurations:
      1. The house is about 250m2 (2690 ft2). About 10 of these devices are outside (garden, front area), total property is about 1100m2 (11840 ft2).
      2. Distance router to first router is now about maybe 15m in a straight line (it's now in a staircase, walls between it) but is connected via ethernet (I also have a Gigabit switch that is taking care of the cabling, so 1 cable from modem to Orbi and another one running back to the switch). Distance to 2nd satellite to 3rd is about 10 meters (32ft). One brick wall between them.
      3. It's a Zxel ZXHN F670. Why is this relevant, curious? The rest of the house is oblivious to it and it's here for years. The Orbi doesn't have an issue with it. WiFi is turned off on that modem.
      4. Sure, I use good cables. I've also tested them with an ethernet tester. There is no issue with the wired connections. Wired devices do get a DHCP address correctly.
      5. I don't know what version was loaded prior to it. I just had it running without paying attention to it.
      6. Yes, I had to do factory reset as it was already upgraded to the latest version.
      • FURRYe38's avatar
        Reason for asking about ISP modem or ONT is to see if there is any router and built in wifi here. I see this unit you have does have a router and wifi. Additional WiFi noise can cause interferences. Additional router can be problematic as well with having a double NAT condition. Just wanna rule out this as well. Can you let us know what configuration this ONT is in? Please disable any wifi radios on the ONT to help check this if you haven't already.
        For users with built in routers and wifi at the ISP level, what is recommended:
        Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
        Couple of options,
        3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router.
        https://community.netgear.com/t5/Orbi-WIFI-6-AX-AND-Wi-Fi-6E-AXE/Procedure-for-Factory-reset-of-RBS850/m-p/2367505/highlight/true#M53985
        https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
        Try option #2 first...
        What is the brand and model of the LAN switch in between the RBR and the RBS?
        So of wired devices get good IPs and wireless don't, possible wifi issue on handling all those devices that are wireless and the system maybe having an issue or in this new FW version.
        Something to review, might consider downgrading back to v.21 on the RBS first then RBR lastly and after all is downgraded, power cycle the system OFF for 1 minute then back ON with the RBR first, then about 1 minute later, power ON the RBS. See what happens.
